Programming command (message type 1) added for cellocator protocol. It allows to configure the cellocator devices.
Message type 7 is supported for Cellocator protocol: Logged Fragment of Forwarded Data from Serial Port to Wireless Channel. Container fragment is registered as hex string in parameter payload.hex.
Output state change setting is supported for Cello IQ and Cello CAN IQ devices:
Cellocator protocol update is planned for tomorrow 2020-08-27, 12:00 UTC - parsing will be switched to new parsing engine. This is an internal process, no changes in devices' work are expected.
namo Cellocator protocol switch to the new parsing engine is postponed till the next Thursday, 3-Sep-2020 12:00 UTC.
namo Cellocator protocol is updated to new parsing engine
Commands of Cellocator protocol are refactored. The following changes was introduced:
namo Cellocator protocol updated: commands status, reset, track_time, engine_stop, firmware, can, location and prog_cmd are removed.
New settings added for Cellocator CR-300 device: Request Position and Request Connect to Server, Actions tab:
Cellocator protocol updated: added parsing of Message Type 11 > Module 28 > Events:
Parameter acceleration.rms is registered for these events: acceleration RMS value of (X²+Y²+Z²), where each of the axes is in 250µg units.
namo One more Module 28 event is supported for Message type 11 for cellocator protocol:
namo Cellocator protocol updated: added parsing of one more Message Type 11 > Module 28 event:
Time elapsed from the last reception of sensor value is stored into flespi parameter sensor.reading.fix.age
The list of supported devices for Cellocator protocol has been extended to include the following ones:
Some changes in parameters are introduced for Cellocator protocol:
namo Cellocator protocol is updated: deprecated parameters are removed.
Cellocator protocol updated: added new modules of Message type 11:
Cellocator protocol is updated: Event Code 13 (Guest MultiSense raw data) of Module 28 (General Status Event) is supported. The following flespi parameters are registered:
Cellocator protocol is updated: Event code 8 (MultiSense Added) and Event code 9 (MultiSense Removed) of Module 28 (General Status Event) are supported. The following flespi parameters are registered for these events:
The following settings are added for Cellocator CelloTrack Nano device, Actions tab:
