dexif 4.15.0 - Added a wayback button. It will help you to restore previous configurations for flespi items.
dexif 4.19.0 - New item info tab (with Qr code generator for wiatag) - MQTT Tiles integration - MQTT Board integration - Utils now can be a panel Subscribe system topics directly from item info tab Create widgets in one click Also you can do it in telemetry tab And finally, you can share your customized board directly from the integrated MQTT tiles
dexif 4.20.0 - Added items selector Now you can select items from the list for "ids" and "token" fields. Just click hand icon.
dexif 4.21.0 - Added item dependency graph If you open device -> info - you can see which channel can be used to register device messages.
dexif 4.22.0 - Added streams and calcs to the device dependency graph - Item window tab now remembers the active tab by element type - Hide unnecessary tabs for some types of channels (idents, connections, commands) - Style fixes for the utils window - badges for Mqtt and http channels
dexif 4.24.0 - Added functionality for viewing and exporting(kml) device tracks for a certain time period
dexif 4.25.2 - Now you can delete telemetry fields - Exporting device tracks in CSV format, also enabled datepicker modes
dexif 4.26.0 - added a list of all available message parameters with filtering and the ability to export in csv format
dexif 4.31.0 - Added commands tab to channel/device window (now you can send command, add command to command queue, remove command from command queue, copy curl of configured commands)
