kial parameter "gsm.signal.level" renamed to "gsm.signal.dbm"
Extra field for Event number 18 is stored as report.reason parameter
Next Thursday, 23-Dec-2021, message parameter "location.accuracy" parsed from the #LOCA# dynamic tag will be renamed to "position.accuracy". Currently, we're registering the same value for both parameters, and in a week the old name "location.accuracy" will be removed.
kial Old parameter name removed
The protocol will be affected by the change in type of parameters gsm.mcc and gsm.mnc to be installed in 2 weeks - May 23rd, 2022: both parameters that now have type "string" will be stored as "number". The possible leading zeroes in MNC will be ignored (e.g. the value "01" will be stored as 1).
ERM protocol has been changed. gsm. network.type parameter parsed from the #NT# dynamic tag was added.
ERM protocol has been updated, added TrackerWi-Fi device
parameter renaming announcement which will happen in a week (May 22): parameter total.idle.seconds will be renamed to total.idle.time
Added #FIX# and #CU# parameters parsing (flespi parameters: position.fix.type, transmition.channel)
Fixed type 02 confirmation messages being incorrectly stored as empty telemetry messages
Added server ACK response for type 06 event messages, enabling bulk message delivery for devices configured to require acknowledgment
Fixed parsing of engine.ignition.status parameter — was incorrectly set to true for events without explicit ignition extra fields (events 14, 15, 18, 33, 44, 45, 48, 49, 50, 90, 91, etc.). Now correctly reflects actual engine state.
true
New parameter engine.status added — engine running state from #ENG# dynamic field and Events 24/25 (Engine On/Off). Previously, #ENG# incorrectly wrote to engine.ignition.status, overwriting the correct ignition value from #IGN#. Now #ENG# and #IGN# produce independent parameters: engine.ignition.status for ignition state, engine.status for engine running state.
#ENG#
#IGN#
New iButton attached/detached events (EID 46/47) are now supported with ibutton.code and ibutton.connected.status parameters.
ERM protocol is updated:
ERM protocol is updated: message type 35 - external device OTA FW upgrade status report - is supported.
erm: Added parsing of voice call events - Voice callback (EID 37), Voice call started (EID 38), Voice call ended (EID 39). New parameters: call.type, call.type.enum, call.phone.number, call.return.code, call.duration.
Fixed parsing of External Device (EID 33) events whose binary payload contains * or $ bytes. These are now correctly de-stuffed per the v2.16+ wire format, resolving a framing error that could disconnect affected devices.
