Extended field 0xFE of type 0x36 known as "call record" parsing added for fields: call.type call.type.enum call.phone.number call.timestamp call.duration
Fixed case of D13 command parsing which could cause unexpected command response behavior.
Meitrack protocol has been updated, added 0x39 Magnetic card reader parameter (flespi name magnetic.card.data)
New setting C03 - GPRS Event transmission mode is added for models (MD500S,MD511H,MD522S,MD533S,MD811H,MD822S,)
Minor improvements to parsing extended tags for the CCE package that blocked parsing. The change is available for tag 0xFE60.
Custom Command added. Custom GPRS command and Custom SMS command are now obsolete and will be removed in 2 weeks - 28.06.24
YuryAheichyk update installed, the old Custom GPRS command and Custom SMS command have been removed
CCE ID 0x4C responsible for analog input voltage parsing added
CCE ID 0x68 parsing to x.tilt.angle, y.tilt.angle and z.tilt.angle added
Correct command response parsing for the command CC7 added
Custom command updated: additional check for command_type parameter added: it can not be longer than 3 characters.
Report type 110 data representing Transparent CAN data is now stored as payload.hex message parameter.
Added new device Meitrack T399 Y41
Added new device Meitrack T711L
Added new devices:
Added new device:
Meitrack protocol is updated: parsing of Wifi MAC addresses is refactored.
