Can anyone tell me the correct command syntax to use with flespi Toolbox in order to request a GPS position update from a CalAmp GPS device?  I know that CalAmp Report Type 8 is a GPS Location Report.  I know that I can send and SMS to CalAmp using syntax !R3,1,255  and that will cause CalAmp to repond with position update (and an event code 255) to whatever server is programmed into the CalAmp device.  I also know that if I am connected to CalAmp serial port, I can use send AT$APP GPS? and it will obtain GPS update.   But I would like to know what to send over the GPRS channel.   I think all commands sent to CalAmp devices ove a GPRS channel should be in Hex.
Whatever I tried so far returns "NAK (not a supported operation)"  in Toolbox.  I am trying to send the commands via Ruhavik.   It should be noted that if I send a position request to CalAmp devices using Wialon, I get the proper response. But I don't know exactly WHAT Wialon is sending.
Any help would be appreciated.
Jules
