• Protocols
  • Teltonika FMB003 with Teltonika EYE sensor
Hi,
I am using a Teltonika FMB003 with a connected Teltonika EYE Sensor for getting the current temperature and humidity in the car. The FMB003 pushes all attributes to flespi - the attributes provided from the EYE Sensor are included. Please see screenshot:
Values have incorrect decimals.
Actual temperature is 16,67°C
Actual humidity is 60%
Is that an issue in the flespi implementation of the Teltonika protocol?
Thanks
Michael
    abcklaus Hi Michael. Could you reach out to us via chat in your flespi.io panel so that we review the actual data in your account and get back to you with the definitive answer?
      I think you can use multiplier in FMB920's advance configuration to change this like setting multiplier to 0.1 for temperature and 10 for humidity . Should work , also I think you can make use of plugin in Flespi to do conversion or in your own application you can apply mathematical calculation.
      Hello.
      Yes, this is a known issue.
      We will fix it soon.
      In the meantime, you can bring the value to the correct one using the method that ysv described.
      I also recommend subscribing to the Teltonika protocol changelog
      dexif Many thanks for your reply. Will wait for the protocol fix.
      8 days later
      I can confirm that temperature is displayed correctly after the change:
      Just humidity is still incorrect - factor 10.
        Write a Reply...
