namo Old parameters removed.
Parameter renaming in maxtrack protocol: engine.ignition.state.enum parameter is renamed into ignition.state. Both parameters will be registered during one week. 17-Apr-2020 old parameter engine.ignition.state.enum will be removed.
namo Maxtrack protocol updated: old parameter engine.ignition.state.enum is removed after renaming.
New parameters parsing added for Maxtrack protobuf devices: Events: configuration.change.event battery.fail.event power.state.enum ignition.event input.active.event output.active.event configuration.change.event gnss.state.enum alarm.panic.status external.powersource.status gnss.antenna.status battery.fail.event gsm.jamming.alarm.status sleep.mode.status alarm.mode.status battery.low.status Device details: product.model.enum battery.level battery.voltage power.state.enum device.temperature device.uptime device.lifetime battery.use.duration reboot.reason.enum last.reboot.id vehicle.battery.state Connectivity block: wifi.status zigbee.status gsm.jamming.event gsm.sim.status gsm.module.status gsm.module.status gsm.network.roaming.status gsm.network.status gsm.network.status gsm.mcc gsm.mnc gsm.lac gsm.cellid gsm.signal.dbm gsm.timing.advance Ignition calibration block: ignition.calibration.automatic ignition.calibration.timestamp ignition.calibration.min.detected ignition.calibration.max.detected ignition.calibration.min.used ignition.calibration.max.used ignition.calibration.voltage
Maxtrack protobuf part bugfix: parameter extnav.position.speed renamed to position.speed
Maxtrack binary protocol GPS rollover issue fixed: If timestamp of the message received is less then current time for 619315200 seconds with +/- 24 hours then timestamp is shifted by GPS epoch seconds forward.
The protocol will be affected by the change in type of parameters gsm.mcc and gsm.mnc to be installed in 2 weeks - May 23rd, 2022: both parameters that now have type "string" will be stored as "number". The possible leading zeroes in MNC will be ignored (e.g. the value "01" will be stored as 1).
Bugfix for binary protocol. Parsing for digital input states added: boolean parameters din.1, din.2, din.3, din.4 and its number bitmask din
Maxtrack binary protocol has been updated:
parameter renaming announcement which will happen in a week (May 22): parameter total.idle.seconds will be renamed to total.idle.time
Added settings for working with the list of accessories
