Atrack protocol is updated: %DC (Distance traveled since DTC codes cleared, km) custom field is supported. It's value is registered into flespi parameter can.dtc.cleared.mileage. This change is applicable to ATrack AX11 device model.
Atrack protocol is updated - the following J1708 CAN data fields are added:
The update is applicable for ATrack AK11 device.
New custom fields are added for Atrack protocol:
Output Control settings are added for ATrack AK11, ATrack AK7V and ATrack AK7S devices, INPUT/OUTPUT tab:
kial "J1939 Information Format" (AT$FMSC) and "J1708 Information Format" (AT$1708) settings supported for ATrack AX11 device.
ATrack protocol updated: parsing of the following J1939 custom data fields is fixed:
The protocol will be affected by the change in type of parameters gsm.mcc and gsm.mnc to be installed in 2 weeks - May 23rd, 2022: both parameters that now have type "string" will be stored as "number". The possible leading zeroes in MNC will be ignored (e.g. the value "01" will be stored as 1).
ATrack protocol updated: fixed parsing of %EH custom field (parameter can.engine.motorhours)
ATrack protocol is updated: added J1939 Information Format and J1708 Information Format settings (Configuration tab) for ATrack AS11 device type.
ATrack protocol updated: added system parameter timestamp.key. The parameter is used to distinguish between two messages with the same timestamp of seconds granularity. Integer part of its value is a message timestamp, and the fractional part is a Seq. ID of the message plus index of the report in packet. This will prevent merging of messages with the same timestamps measured in seconds into one message in device database:
ATrack protocol is updated: J1939 Information Format setting (Configuration tab) is added for ATrack AK7S device type:
ATrack protocol is updated: added custom command for Atrack devices. The command can be sent either via GPRS connection or via SMS.
Along with this, at command is marked as deprecated in will be removed. Please, use custom command instead.
namo , Deprecated at command removed
New device types added:
Info setting remastered to store separate fields:
ATrack protocol updated: parsing of the VIN number field %VN fixed. (parameter vehicle.vin)
ATrack protocol updated: Text Message parsing fixed for historical messages (driver.message parameter)
Atrack protocol is updated: fixed parsing of DD (Driver ID) custom field for ASCII reports.
Atrack protocol implementation is remastered so that device identification has become more flexible. Previously, in order to identify the device and continue parsing according to the device's Position Report Format setting, the protocol expected 0xFE02 Heartbeat packet to be received the first in the newly established connection. The updated implementation also accepts Position report packets with default header prefix @P as an identification packet.
