This is a changelog topic for AEMP protocol.
AEMP is a universal protocol used by various makes of heavy equipment that export telematics data according to AEMP 2.0 (ISO 15143-3) standard.
AEMP protocol is updated: protocol has moved to the new telematics gateway engine. This is an internal process, no changes in the work of the channel is expected.
AEMP protocol is updated: enabled access to raw HTTP traffic between flespi and AEMP HTTP server. You can find it under "Logs & Messages" tab of the channel. This can be used to debug any kind of communication issues.
Bugfix. Parameter fuel.level parsed from XML field FuelRemaining had been incorrectly stored as string, now stored as number
AEMP protocol is updated: added oAuth1.0 authorization
AEMP protocol has been updated, added default header Accept: application/xml
AEMP protocol has been updated, fixed total.idle.seconds parameter parsing
Added handling of response code 429 Too many requests
Bugfix: configured URI query parameters (e.g. addMetadata, addExtendedData, includeOffRentAssets) are now preserved when following server-provided pagination "next" links. Previously only the first page request included the full URI.
OAuth2.0 Bearer: token endpoint response is now accepted as a plain text token, not only as a JSON document
