Sinocastel protocol updated: added parsing of TLV 0x1705: International mobile subscriber identity (IMSI)
Sinocastel protocol updated: G-Sensor data packet is supported (accelerometer data)
Sinocastel protocol updated: protocol IDs 0xD004 and 0xD005 supported - Firmware upgrade result
Additional OBD-II PIDs are supported for sinocastel protocol.
vehicle.vin parameter parsing added OBD pids 2123(fuel pressure) and 214F(oxygen sensor max values) parsing added
OBD-II PIDs supported:
Supported OBD-II PID 0x2102: DTC that caused freeze frame data capture - parameter can.freeze.dtc
Supported OBD-II PID 0x2112: commanded secondary air status - parameter can.secondary.air.state
The following OBD-II PIDs are supported:
Sinocastel protocol updated: Parameters power.on.event and power.off.event are replaced by power.on.status parameter:
Sinocastel protocol updated: integer parameter position.fix.type showing if the position is 2D (value = 1), 3D (value = 2) or not fixed (value = 0) added
Supported OBD-II PID 0x214E: engine run time since DTCs cleared - parameter can.dtc.cleared.engine.time
Sinocastel protocol updated: supported protocol id 0x4008 - Cell ID
Supported OBD_II PID 0x2131: EVAP system vapor pressure - parameter can.evap.vapor.pressure
Sinocastel protocol is updated - the following OBD-II PIDs are supported:
New OBD-II PID is added for sinocastel protocol: 0x2152 - Alcohol fuel percentage (%), flespi parameter: alcohol.fuel.percentage
New OBD-II PIDs are supported for sinocastel protocol. Mapping to the flespi parameters is below:
Sinocastel protocol is updated - added getparam command:
New PIDs are supported for sinocastel protocol. Mapping to flespi parameters is as follows:
