General-motors-onstar protocol is supported by flespi telematics hub.
The channel is capable to receive telematic messages pushed by OnStar platform as HTTP POST requests, and send commands to vehicles via OnStar REST API.
[Changelog] general-motors-onstar protocol
The following settings are available for General-motors-onstar devices, Actions tab:
- Location
- Lock/Unlock Door
- Enable/Disable Ignition
- Alert/Cancel Alers
General-motors-onstar protocol updated: added Commands setting (Actions tab) that fetches the names of all commands that are available for the device.
The names may be used as Command Name field values in Custom command.
New CAN parameter integrated for general-motors-onstar: WASHER_FLUID_LOW => which is stored into can.washer.fluid.level.low.indicator.status flespi parameters.
Added source telemetry information to the protocol page: https://flespi.com/protocols/general-motors-onstar#parameters
general-motors-onstar protocol has been updated, new parameters added:
- EHPE - flespi name position.accuracy
- AGEIND - flespi name position.valid
Fixed DTC data registration
Fixed can.vehicle.speed parameter registration, added new can.vehicle.speed.valid parameter
Added an action setting Remove consent
