We have adjusted the internal configuration to achieve a more stable stream with optimal throughput.
The maximum size of published message is set to 2 KB.
The maximum number of inflight messages is set to 3.
Please contact us if you would like to customize these settings yourself.
    2 months later
    We've added the ability to set the maximum payload size of a published message in Thingsboard. Larger messages will be discarded.
    2 years later
    Added publication to the v1/gateway/connected topic of a newly connected device to automatically create the device
    10 months later
    Stream logs were rebuilt. Now, a log is registered for each message received by the stream. If the message was not sent, the log contains the reason.
      Write a Reply...
