This is a change log for a flespi stream to the National Poland E-Toll system https://etoll.gov.pl/
We fixed an issue with message filtering that caused a stream to report device messages more often than 5 seconds. Added a new log message for each device that sends messages.
Stream logs were rebuilt. Now, a log is registered for each message received by the stream. If the message was not sent, the log contains the reason.
Also, the stream can now send historical messages.
Added the "Minimum message interval" stream setting: the minimum number of seconds between two consecutive location points of the same device. Messages that arrive earlier than that are skipped. The default is 5 seconds, and lower values are not allowed because e-TOLL accepts no more than one location point per 5 seconds. Raise it to send location points less frequently
