Hi, I'm trying out the wialon-lbs-geocoding
plugin, but I don't see the position.lbs.latitude
and position.lbs.longitude
fields in device messages and no messages appear in the plugin itself.
My devices are FMC001 and TAT100 and they are sending mnc, lac and cellid. Could it be that LBS doesn't work, because there is no mcc?
When I check Utilities - Message Parameters - Teltonika protocol, the mcc parameter is also not there. So, does LBS work with Teltonika at all? At the same time, Gurtam documentation claims that Teltonika does support LBS.
