We've added Positioning Universal protocol implementation.
The list of supported devices: FJ1500LA FJ1500LS FJ1500MG FJ2050LA FJ2050LS FJ2050LV FJ2500LA FJ2500LS
Positioning-universal protocol is updated: Sending of acknowledgements for Location Messages now solely depends on the value of Ack Indicator bit.
Positioning Universal protocol has been updated. Fixed custom fields 0-26 parsing: now they are parsed as unsigned integers.
Some Positioning Universal event IDs now also are saved as standard flespi parameters:
Support of OBDII reports has been updated in Positioning Universal protocol:
Positioning Universal protocol has been updated: if minor map specifies both absolute and delta values for timestamp, latitude and longitude, then absolute values are ignored and only deltas are used.
Positioning Universal protocol has been updated: zero-length extended fields parsing error has been fixed.
Positioning Universal protocol has been updated: Device/Ignition state field is now parsed as a bitmap value.
Positioning Universal protocol has been updated: DTC data field of unexpected length (not a multiple of 5) is not chopped into items of can.dtc.array parameter but saved as is in can.dtc parameter.
