I'm trying to establish connection between a Omni OGB1 smart lock and flespi. I have tried setting up the configuration on the Flespi Telematics Hub but cant seem to find a solution. When I try to execute a command I get failed to deliver command 'setting.s0_ogb1.set' with timeout pending, device with id 2257065 is not connected .How can I send device configuration using sms.
Thanks
Omni OGB1 Device not connected
SongaSonga In order to correctly send commands to omni device you should configure it first to send data correctly to appropriate channel's host and port. How did you configure the devices' server and apn settings?
SongaSonga this guide shows how to connect concox device. But different devices have different ways to set up APN and server settings. So it is your supplier who has to tell you how to configure the device. When you figure it out - you can post it here.
Hi,
Reviewing this post, we are aware that we need to point the lock to a specific server:port of Flespi to get the lock to function correctly. My question is, how can we point the lock to an specific address? Is there an SMS way?
You can set the Ip and port on a ogb1 by using the BLE tool provided by Omni, You will have to contact Omni and get a code to be able to register the ble tool ad get it to work.
