New settings are added for thinkpower protocol:
Configuration tab:
Alarm tab:
Bluetooth tab:
Actions tab:
Numerous settings are added for Thinkpower devices:
Thinkpower protocol support is enhanced. Below is a mapping of thinkpower values types into flespi parameters:
Thinkpower protocol is updated: new value types are supported and are parsed into the following flespi.parameters:
Thinkpower protocol updated: value type 0x1A INP is now parsed into the following parameters:
Thinkpower protocol is updated: fixed <Payload length> value for the Message type 0x02: Login reply
Protocol update: mapping of thinkpower values types into flespi parameters:
Protocol update: mapping of ID 0x52 to parameter door.open.status
Custom command added, e.g:
Thinkpower protocol has been updated, added General indication section (Record value 0x61) parsing
Thinkpower protocol has been updated, added B+ overvoltage (0x27), Supply voltage (0x28) parameters parsing
Thinkpower protocol has been updated, added 0xB1 - Temperature multi, 0xB2 - Humidity multi, 0xB3 - Door-multi, 0xB4 - TPMS multi value types parsing
Thinkpower protocol has been updated, added 0x65 - ICCID value parsing
parameter collision.alarm renamed to crash.event parameter towing.alarm renamed to towing.alarm.status parameter alarm.event renamed to sos.alarm parameter battery.low.alarm updated parsing rule: only true value will be stored parameter power.cut.alarm updated parsing rule: only true value will be stored parameter overspeeding.status updated parsing rule: only true value will be stored parameter trip.time updated parsing rule to trip.duration
