Charging base location setting added
YuryAheichyk Changes applied
Added SMS password configuration field for Eview devices The SMS password will be added to the SMS command text during execution
Fixed Call 1 Button Settings setting execution
Eview protocol updated: timestamp for key 0x23 (BLE Location) is taken now from key 0x24 (General data), if possible. The update is applicable for EV-07B devices.
Eview protocol updated: for Eview EV-07B devices parameter timestamp.key is added for all messages that are registered from 0x01 Data Command Key's.
timestamp.key is a synthetic parameter that is calculated based on the timestamp reported by device, packet sequence number and sequential number of the Key information in the 0x01 Data Command packet, that prevents merging of different messages with the same timestamp in the device's storage. Read more about this parameter here.
added support for Health Data 3rd Device messages (packet 0x64) with heart.rate, spo2.rate, perfusion.index, blood.pressure.systolic, and blood.pressure.diastolic parameters
Added GEO Alert Detect configuration setting for EV-04, EV-05
Eview protocol is updated: parsing of Wifi and Bluetooth MAC addresses is refactored.
Eview protocol is updated: Firmware upgrade action setting is remastered to be a command. The firmware_upgrade command is available for EV-07B, EV-201M, EV-206M device types.
Eview protocol is updated: the following setting are added for EV-06 device type:
Voice Prompt (System Params tab)
New Find Me (Actions tab)
The Personal Info setting for EV-06 devices is now available in the flespi panel under Configuration tab. You can configure name, sex, birthdate, blood type, height, weight, and profile URLs directly through the UI instead of using custom binary commands.
New device type added: Eview EV-12
Improved Scan BLE setting: latitude and longitude are now optional — if not provided, device's last known GPS position from telemetry is used as fallback.
New data command keys supported for EV-12:
New setting added for EV-12: Continue Locating, Actions tab
Fixed gsm.signal.dbm parameter: now stores actual dBm values (converted from raw signal strength index using standard AT+CSQ formula) instead of raw 0-31 index.
New setting added for EV-04, EV-05, EV-06, EV-07B, EV-09, EV-202 and EV-12 devices: Extra Enable Control, System params tab — 30 boolean feature toggles including VoLTE disable, BLE controls, home alerts, power saving, beacon modes, and more.
New setting added for all supported devices: Welfare Check, Alarm tab New setting added for EV-04: Welfare Check Control, Actions tab
New wifi.signal.strength and wifi.mac.address parameters added for WiFi Towers (key 0x22) in Services Command context for all eview device types.
