Sierrawireless protocol is updated.
Configuration of telematic reports is now stored in the Report Columns setting of the device (Configuration tab):
![](https://forum.flespi.com/assets/files/2022-08-25/1661411199-416501-onpaste20220825-100629.png)
Parsing of telematic reports is made according to the Report Columns setting of the device.
If you have changed the report composition in any means other than through the flespi setting (e.g. via SMS or through Serial Port), you need to synchronize the setting with flespi device. To do this click the "Request setting from device" (red round arrow) button for Report Columns setting.
⚠️ Please note that column 28 (Serial Number) must be at the first place in Report Columns configuration. This is necessary for the server to identify the connected device.
⚠️ If Report Columns setting is not set (for example you didn't create a device in flespi), then server will query the columns configured for the device with the DIAG PARAMS=24 command upon each connection.
