• Integrations
  • Help with retransmitting Howen MA8008 data in JSON format via API
Hi everyone!
I’m a Wialon platform user, and one of our clients has requested to retrieve and retransmit data from their Howen MA8008 devices. We need to extract key position data, specifically:
Mobile ID
Latitude
Longitude
Speed
Date
Time
We are considering using Flespi to manage this task by creating an API using the GET method, which will provide the necessary token for access. The response format should be JSON, including all the data mentioned. The API should be available for queries as often as needed.
I’m new to Flespi and would appreciate any guidance on how to set up this data retransmission via the platform. If there is any documentation or useful examples on how to accomplish this, I would be grateful if you could share the links.
Thanks in advance for your help!
    Write a Reply...
