Hello, I am new to flespi and I have several questions about commands using the MQTT protocol and other issues. I have already created an MQTT channel using the flespi broker, I used the necessary credentials and I subscribed to the topic correctly, in the "ident" section of the channel I created a new device with the same MQTT protocol, then I assigned this device to a stream with wialon-flespi-gateway protocol and in wialon the parameters are sent correctly but it appears that it is "offline".
What interests me most is to know why in the commands section on the device I cannot create new commands, when I click on "new command" I cannot do absolutely anything in the window that emerges.
What am I doing wrong?
please help me
MQTT "New commands"
- Edited
Hello. Unfortunately, commands and settings are not available for the MQTT device.
"Connected" status is also not supported for this device type.
oh ok, thank you very much. greetings!!
