New feature is now available in calculators configuration - special boolean property update_onchange.
This property controls the behavior of analytics system when calculator configuration is changed.
With TRUE value (default) the system will synchronize all devices intervals according to a new calculator configuration within update_period (10 days by default). So if you change selectors, counters, or validation fields - you will immediately see the effect with intervals created, updated, deleted events. This is standard behavior of flespi analytics from the very beginning.
While FALSE value will prevent any automatic synchronization to currently existent intervals and will only use the new configuration for new device messages processing. This is convenient to use in production level calculators with thousands of devices assigned to prevent flooding of your handlers with intervals update events.
In order to provide our users with precise control we also added new method that will force analytics system to apply current configuration of calculator to a specific range of device messages: POST /gw/calcs/XXXX/devices/XXXX/recalculate. This can be convenient to force intervals synchronization for historical device messages beyond standard update_period.
