Hi, i have a problem with a toggle widget on my project. I have 2 telemetry variables (dout.1 and dout.2) , values 'true','false'. Then i have a setting named Digital Output that have dout.1 and dout.2. I can change the values in settings but i can't change the values on my MQTT tile. Here is the configuration of my toggle widget..
Toggle Widget does not work
DavidSoriano What you publish to flespi/rest/... must correspond the REST API call to trigger digital output. In your case it is setting called "setdigout_2"
You may go to device->settings->input/output->"Action command setdigout" and click on curl:connection to see REST API request format.
flespi/state/gw/devices/{id}/telemetry/... topic is read-only, you can't publish to it.
ok, but in True Action Topic on toggle widget i write "flespi/gw/devices/5078900/settings/outputs2" but does not work,....
DavidSoriano your first intention to use topic like flespi/rest/put/... was correct.
MQTT Tiles can work via MQTT only, so in this section you use feature called REST API over MQTT
then, what is the solution?
dout1 on: {"properties":{"out1":{"state":"1"}},"address":"connection"}
dout1 off: {"properties":{"out1":{"state":"0"}},"address":"connection"}
You have to swap "True/False action payload"
ok, i got it, but from when i execute the action until when the button changes from red to green (0->1) there is a lot of delay, like 30 seconds... is there any way to make it faster?
No, because it is waiting for a response from the device.
thanks
flespi sends command as soon as it receives some packet from device. You may configure ping packet in Teltonika device for e.g. 5 seconds, thus device will send some byte each 5 seconds, and the command will be sent and executed faster. But it may result in higher mobile data consumption.
