Change of settings for the V series.
Added Uplink Transparent Transmission (0x0900) message parsing
Added parsing for the alarm flags in the GL100 model.
aovx protocol update: now TLS option can be enabled for the channels to setup receiving secure and encrypted SSL connections from devices.
aovx protocol is updated: fixed finishing of command that is sent as configuration setting
Update planned: in 1 week September 3rd and ending index will be removed from parameters: sensor.illuminance.1 sensor.temperature.1 sensor.humidity.1 x.acceleration.1 y.acceleration.1 z.acceleration.1
baja update installed
Fixed a bug where devices with an identifier starting with 0 could not connect to the channel
ble.sensors array-type parameter renamed to ble.beacons. Also there is extra field id added to every sensor object in the format: ident-index
Added new command Transparent data for V-Series devices
AOVX protocol is updated. Empty idents (i.e. Device Unique ID is sent as binary zeroes 000000000000) now don't cause parsing error followed by disconnect if device connection is already identified.
Fixed gsm.network.type parameter registration for V- series devices
Aovx protocol is updated: parsing of Wifi and BLE MAC addresses is refactored.
