New device model: Barra GPS
Parsing update: High-G Event data now is supported. Parameters that are registered by this package: max.acceleration - Peak G force (1024 = 1 G) avg.acceleration - Average absolute value of G force (1024 = 1 G) max.acceleration.duration - Duration of the acceleration (Milliseconds). Is recorded in seconds. Example: 20 milliseconds = 0.02 seconds.
Added debug.level, debug.module.id, debug.info parameters instead of error.level and error.type.description
Parameters error.level, error.type.description will be deleted in two weeks 16 Sep 2024
YuryAheichyk updates installed
Added parsing of BLE 'Eddystone TLM Frame''.
Added parsing for FID = 36: Multi Cell Tower Scan. Parameters parsed: gsm.cell.type gsm.network.type gsm.cellid gsm.lac gsm.mcc gsm.mnc gsm.timing.advance network.signal.rsrp network.signal.rspq gsm.earfcn gsm.cellid.physical gsm.timing.difference
New device type added - Manta Fusion REJECTED: device may work only through digital-matter-edge protocol
Added registration of the battery.health.status parameter from the FID=2 structure. The parameter has an index of 1 bit (starting with 0). If true - everything is fine with the battery, false - replacement is required.
Fixed rssi and state values registration from BLE tags
Added 15, 151, 152 counters values registration to resets.brownout.count, resets.count, reboot.count parameters
Digital-matter protocol is updated: fixed parsing field length for data records
New device type added: Digital Matter Arrow Global BLE
