0.1.0
[feature] By default, the zoom controls are hidden. Use the command to activate.
[feature] Added the ability to add and remove polygons.
    8 days later
    0.1.1
    [feature] markers for start/stop positions of routes. To disable it use: MapView|cmd:{"showstartstop":false}
    [feature] new style for markers
    • Edited
    0.1.2
    [feature] fullscreen mode button. Disabled by default. To enable use: MapView|cmd:{"fullscreencontrol":true}
    To allow this feature please add attribute "allowfullscreen" to iframe.
    0.1.3
    [feature] Route direction. Enabled by default. To disable use: MapView|cmd:{"routedirection":false}
    0.1.4
    [feature] new styles for start/stop pins
      a year later
      0.2.0
      - Added named markers with cumulative tail
      - Salt for commands by route parameter
          Example:
              Iframe uri: https://flespi.io/mapview/index.html#/salt/78985d8a
              Commands will be like: MapView-78985d8a|cmd:{...}
      - Sandbox updated
      https://flespi.io/mapview/#/example
      2 months later
      0.2.2
      - Added autobounds command
        cmd:{"autobounds": true}
      - Added centermap command
        cmd:{"centermap": [53.90557,27.45642]}
      - Added zoommap command
        cmd:{"zoommap": 10}
      22 days later
      • Edited
      0.3.0
      - Added direction, addpoints, setpoints, label, title parameters for named markers
      You can try it on https://flespi.io/mapview/#/example
      a month later
      • Edited
      0.4.0
      - Added color for named markers
      - Added markercolor (default color for named markers)
      - Added trackcolor (default color for tracks)
      - Fix for marker direction
        3 months later
        0.5.0
        - Added the ability to snap a raster plans to map
        You can use it for example to show unit positions on building plans (indoor monitoring with ble beacons).
        Or you can add old maps as a layer
        Usage example available on https://flespi.io/mapview/#/example
        23 days later
        • Edited
        You can now use the ruler on the map to measure distance.
        To enable ruler functionality you should send ruler: true command to mapview.
        This functionality already available in
        • Panel -> Device -> Telemetry tab
        • Toolbox -> Device -> Map
        • Toolbox -> Calculator -> Intervals
        6 days later
        A simple example to get started using MapView:
        <script>
            function send () {
                var cmd = { "clear": "all", "namedmarkers": { "markername": { "title": "Marker title", "appendpoints": [[53.90557, 27.45642], [53.90951, 27.45633], [53.91391, 27.45968], [53.91695, 27.46904], [53.91573, 27.47599], [53.91422, 27.46784], [53.91179, 27.46285], [53.91235, 27.46751], [53.91170, 27.47155], [53.90973, 27.46262], [54.844636600000015, 21.426025400000015]], "label": "markerlabel" } } }
                document.getElementById('map').contentWindow.postMessage(`MapView|cmd:${JSON.stringify(cmd)}`, '*')
            window.addEventListener('message', function (event) {
                console.log(event)
                if (typeof event.data === 'string' && event.data.indexOf('MapView|') === 0) {
                    var cmd = {}
                    try {
                        cmd = JSON.parse(event.data.replace('MapView|state:', ''))
                    } catch (e) {
                    if (cmd.ready) {
                        send()
        </script>
        <iframe id="map" src="https://flespi.io/mapview/" frameborder="0" style="height:500px;width:100%" allowfullscreen></iframe>
        Also you can read article about mapview
          a month later
          Added popup for named markers
          MapView|cmd:{"namedmarkers": {"test":{"latlng":[53.9065366,27.4618254], "direction": 354, "color": "#f0f", "label": "label", "popup":"Popup that opens by clicking on a pin"}}}
          a month later
          0.6.4
          Now you can apply some styles to the dot markers:
          MapView|cmd:{"dotcolor": "#006600", "dotradius": 10, "dotsolid": true}
          a month later
          0.7.3
          Draw/Edit tools
          • Polygon
            MapView|cmd:{"polygons": {"test":{"path":[{"lat":53.90557,"lon":27.45642},{"lat":53.9,"lon":27.4},{"lat":53.9,"lon":27.3},{"lat":53.7,"lon":27.3}], "color": "red", "edit": true, "editable": true, "deletable": true}}}
          • Corridor
            MapView|cmd:{"corridors": {"test":{"path":[{"lat":53.90557,"lon":27.45642},{"lat":53.9,"lon":27.4},{"lat":53.9,"lon":27.3},{"lat":53.7,"lon":27.3}], "width": 100, "color": "red", "edit": true, "editable": true, "deletable": true}}}
          • Circle
            MapView|cmd:{"circles": {"test":{"center":{"lat":53.90557,"lon":27.45642}, "radius":10000, "color": "red", "edit": true, "editable": true, "deletable": true}}}
          Change tiles source
          MapView|cmd:{"url": "http://stamen-tiles-{s}.a.ssl.fastly.net/toner/{z}/{x}/{y}.png"}
          MapView|cmd:{"url": "https://server.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer/tile/{z}/{y}/{x}"}
          MapView|cmd:{"url": "https://{s}.tile.openstreetmap.org/{z}/{x}/{y}.png"}
          a year later
          0.9.3
          - hidecontrols command added
          Example:
          MapView|cmd:{"hidecontrols": true}
          2 years later
          0.9.11
          - fix corridor linecap
          2 months later
          0.10.0
          Now you can pass any command in the url using the cmd query parameter (json or base64 encoded json)
          Example
            Write a Reply...
